Pvwattsv8 results in SAM and PySAM
- Javier
23 Jun 2023 06:22 #12247
by Javier
Pvwattsv8 results in SAM and PySAM was created by Javier
I’m getting different results in SAM and PySAM. This is a nexample for Pvwattsv8 with my own custom weather file. I only changed in SAM the system capacity to 100 MW, I generate the code to PySAM JSON and import it in Python. This works fine, with minor differences.
SAM results
But when I change the system_capacity to 500 MW, I get quite different values for the LCOE nominal.
SAM results
This is the Python code.
Am I missing something in the Python code? Thanks.Best regards,
Javier.
SAM results
PySAM results
PV capacity: 100.0 MW
PV power: 186,487,766 kWh
PV capacity factor: 21.3 %
PV LCOE nominal: 4.9 c$/kWh
PySAM results
PV capacity: 500.0 MW
PV power: 932,435,679 kWh
PV LCOE nominal: 2.01 c$/kWh
import json
import PySAM.Grid as Grid
import PySAM.Pvwattsv8 as Pvwattsv8
import PySAM.Singleowner as Singleowner
import PySAM.Utilityrate5 as UtilityRate
def execute_modules(modules):
for m in modules:
m.execute()
def load_modules(path, file_names, modules, execute=False):
for f, m in zip(file_names, modules):
with open(f'{path}/{f}.json', 'r') as file:
data = json.load(file)
for k, v in data.items():
if k != "number_inputs":
m.value(k, v)
if execute:
def load_pv(path, file_names, execute=True) -> [Pvwattsv8, Grid, UtilityRate, Singleowner]:
pv = Pvwattsv8.new()
pv_grid = Grid.from_existing(pv)
pv_ur = UtilityRate.from_existing(pv)
pv_so = Singleowner.from_existing(pv)
modules = [pv, pv_grid, pv_ur, pv_so]
load_modules(path, file_names, modules, execute)
return modules
if __name__ == '__main__':
# PySAM JSON path and files
pv_path = '/home/javi/Documents/PycharmProjects/IDA_2023/data/PV_watt_json'
pv_file_names = ['untitled_pvwattsv8', 'untitled_grid', 'untitled_utilityrate5', 'untitled_singleowner']
# Load PV modules, execute and show results
[pv, pv_grid, pv_ur, pv_so] = load_pv(pv_path, pv_file_names)
print(f'PV capacity: {pv.value("system_capacity")/1000:,} MW')
print(f'PV power: {round(sum(pv.Outputs.gen)):,} kWh')
print(f'PV capacity factor: {round(pv.Outputs.capacity_factor, 1)} %')
print(f'PV LCOE nominal: {round(pv_so.Outputs.lcoe_nom, 2)} c$/kWh')
print('\n')
# Change capacity
capacity = 500 * 1000 # kW
pv.value('system_capacity', capacity)
# Execute and show results
execute_modules([pv, pv_grid, pv_ur, pv_so])
Javier.
30 Jun 2023 09:13 #12268
Replied by Paul Gilman on topic Pvwattsv8 results in SAM and PySAM
Hi Javier,
Please attach or post a copy of your Python script with correct indentation and a copy of the .sam file you are using for the comparison if you would like me to help troubleshoot.
- Javier
03 Jul 2023 05:48 #12271
by Javier
Replied by Javier on topic Pvwattsv8 results in SAM and PySAM
I provide a link where you can find the Python code, the SAM project and the weather CSV file, thanks.
Javier.
Javier.
- Javier
25 Jul 2023 01:13 #12348
by Javier
Did you have time to have a look at this? Thanks.
Javier.
Javier.
27 Jul 2023 15:19 #12355
Hi Javier,
Thanks for the reminder.
I am getting the same results from PySAM 4.2.0 and SAM 2012.11.21 r3 SSC 280. It is possible the differences you are seeing are because the PySAM and SAM versions you are using are not consistent. To see what versions of SAM go with PySAM versions, go to the Releases list on GitHub: github.com/NREL/pysam/releases .
- Javier
28 Jul 2023 00:55 #12357
by Javier
Thanks for checking. I'm getting same results as yours. The issue is the nominal LCOE provided by SAM is 4.89 c$/kWh, whereas it's 2.01 c$/kWh in PySAM, for the 500 MW PV plant, The 100 MW PV plant yields the same results in SAM and PySAM.
Javier.
Javier.
