Parabolic Trough Steam Booster Heater
15 Jan 2014 10:31 #2088
Parabolic Trough Steam Booster Heater was created by Paul Gilman
I want to include in power cycle of the physical trough a steam booster heater, which will heat up the steam before it enters the turbine. Does SAM has such a component or it has only the HTF heater and steam heater needs to be created manually?
SAM models a backup boiler that uses natural gas to heat the HTF at the solar field outlet to maintain the fluid temperature at its design point. It does not model a steam heater in the power block.
- Vahan Poghosyan
16 Jan 2014 01:35 #2089
by Vahan Poghosyan
Replied by Vahan Poghosyan on topic Parabolic Trough Steam Booster Heater
Then how the steam booster heater can be added to SAM model?
Best Regards
Vahan
Best Regards
Vahan
16 Jan 2014 10:12 #2090
Replied by Paul Gilman on topic Parabolic Trough Steam Booster Heater
Dear Vahan,
It is not possible to model a steam booster heater in SAM.
- Vahan Poghosyan
26 Jan 2014 00:16 #2091
by Vahan Poghosyan
Is there any way to mimic the work of steam booster heater in SAM without modeling it?, booster heaters only function is to increase steam temperature from around 370 C to 540 C before steam enters the turbine, and booster heater works only when solar field operates at or exceeds design conditions.
Best Regards
Vahan.
Best Regards
Vahan.
27 Jan 2014 09:41 #2092
Dear Vahan,
I am not aware of a way to model a steam booster heater in the CSP models.
You could use the performance adjustment factors to reduce the system's total energy output as a way to account for the booster heater's energy, but that would require that you estimate the heater's annual energy requirement outside of SAM.
- Vahan Poghosyan
16 Feb 2014 09:10 #2093
by Vahan Poghosyan
Is there any way to give Hourly Factor in Performance Adjustment section a value more than 1?
Best Regards,
Vahan
Best Regards,
Vahan
