Parabolic Trough Steam Booster Heater
17 Feb 2014 09:59 #2094
Replied by Paul Gilman on topic Parabolic Trough Steam Booster Heater
Dear Vahan,
No, the Hourly Factors on the Performance Adjustment page must be between 0 and 1. If you assign a value greater than 1, SAM automatically changes the value to 1.
You can assign a value to the "Percent of annual output" that is greater than 100%.
Would you mind explaining why you want to use adjustment factors greater than 1? We are making some changes to those inputs for the next version now, so perhaps we could make that possible if there is a good reason for it.
- Vahan Poghosyan
18 Feb 2014 12:59 #2095
by Vahan Poghosyan
Replied by Vahan Poghosyan on topic Parabolic Trough Steam Booster Heater
I found that Hourly Factors are the best way to account for the fossil fuel steam booster heater in parabolic trough plants. For instance I calculated that for the plant that I am modeling the input of booster heater in electricity generation is 45% (booster only increases the temp. of steam from 380 to 540 C subsequently turbine generates 45% more electric energy), so if I use Hourly Factors and adjust power output to 145% I can mimic the presence of booster heater without actually modeling it. Moreover Hourly Factors give opportunity to adjust power output by months and day hours so it is very convenient in case if the input of the booster heater is variable.
With “Percent of annual output”, even though I can input values more than 100%, those results cannot be achieved.
Thus, giving Hourly Factors values greater than 1 will be very useful feature and will increase flexibility of the software.
Best Regards,
Vahan
Best Regards,
Vahan
- Vahan Poghosyan
22 Feb 2014 22:51 #2096
by Vahan Poghosyan
So are you going to include that feature and when the new version will be available?
Best Regards,
Vahan
Best Regards,
Vahan
- Vahan Poghosyan
23 Feb 2014 00:00 #2097
by Vahan Poghosyan
And one more question when I give Turbine Output Fraction value of 2, that's mean I double the thermal input to turbine? or it means something else? because when I give value of 2 to Turbine Output Fraction and allocate that period to all Weekday and Weekend Schedules, results are the same as for Turbine Output Fraction of 1.
Best Regards,
Vahan
Best Regards,
Vahan
24 Feb 2014 10:49 #2098
Dear Vahan,
The Turbine Output Fraction on the parabolic trough's Thermal Storage page is a multiple of the thermal input to the turbine. When you change its value, you should see a small change in the system's total annual output.
The multiplier does not change the power cycle's capacity, so I would not expect to see a large change in the system's output. Also, when you change the TES dispatch multipliers, you may want to re-optimize the solar multiple and TES storage capacity values.
- Vahan Poghosyan
15 Mar 2014 07:50 #2099
by Vahan Poghosyan
In parabolic trough physical how does "Loop optical Efficiency" is calculated?
In SAM help it is written "Loop optical Efficiency = Aggregate SCA Efficiency * Aggregate Receiver Optical Efficiency"
but what does "Aggregate" means here?
Best Regards
Vahan
Best Regards
Vahan
