Generation hours
- Maxim
17 Jan 2025 04:44 #13814
by Maxim
Generation hours was created by Maxim
Greetings!
I have a problem in the simulation: generation starts at 4-5 am in some months, which is not true.
Coordinates: 49.925 36.376
For the simulation were used the NSRDB and ECMWF/ERA resource libraries from PVGIS ( re.jrc.ec.europa.eu/pvg_tools/en/tools.html#TMY ).
I attach the simulation file:
17 Jan 2025 09:43 #13816
Replied by Paul Gilman on topic Generation hours
Hi Maxim,
Please double-check that the time zone information in the weather file matches the time stamps. Usually, this kind of offset is caused by the time stamps being in UTC instead of local standard time.
You might also consider using data from the NREL NSRDB, which you can download directly from SAM's Location and Resource page. Recent versions of SAM can access NSRDB for most parts of the world. I was able to use SAM 2024.12.12 to download a TMY file from the NSRDB for the location in your file.
If you continue to have trouble and would like me to help investigate, please attach an example of a weather file that causes the problem.
- Maxim
22 Jan 2025 02:39 #13828
by Maxim
Replied by Maxim on topic Generation hours
Got your reply Paul, thanks!
It is indeed the wrong time measuring, although the GMT2 zone is correct, also I have updated the SAM version, but the problem still persists.
Probably the problem is in the weather data file, I attach it:
22 Jan 2025 09:14 #13830
Hi Maxim,
This location is at a relatively high latitude near 50 degrees North, so early morning and late evening irradiance makes sense for the summer months. I downloaded a weather file for the same location from the NREL NSRDB and see the same pattern, so believe this reflects the actual available irradiance.
- Maxim
10 Feb 2025 18:49 #13861
by Maxim
Thanks for your reply, Paul! The error is probably the clock forward one hour in the simulation region.
One more question on the topic, I have encountered a bug that with a certain panel orientation: the generation in morning hours can exceed the generation at noon, but this cannot be because of solar radiation diffusion. Can you please tell me what this could be related to? Or is this the correct result? This is observed with all possible models of Sky Diffuse Model in SAM. We have identified the mentioned errors in the "Parametrics" section.
I attach a file of the simulation and the weather data I used for it:
11 Feb 2025 17:20 - 18 Feb 2025 10:18 #13862
Hi Maxim,
It looks like on some days in January, the DNI is higher in the morning than for the rest of the day. This could be a data anomaly, or an indication of a sunny morning and cloudy rest of the day.
Given that the array is facing east (azimuth = 90), I would expect that there might be some days with sunny mornings and cloudy mid-days where the system would generate more power in the morning than in mid-day.
Last edit: 18 Feb 2025 10:18 by Paul Gilman.
