SAM files
- omar mohamud
13 May 2020 13:18 #8195
by omar mohamud
SAM files was created by omar mohamud
Hi all,
I am new to SAM and to the forum..
I have started reading old reference material with videos that have also presentation files and SAM files. I found the material helpful to get started before delving actual modeling.
My understanding is that SAM files, see image, are sample files that can be used as tutorial. But could not find a way to launch them or read them as SAM project files. What am I missing? Perhaps my understanding of these files is not correct.
I have attached an image
Thanks for your help.
Omar
Omar
13 May 2020 15:42 #8196
Replied by Paul Gilman on topic SAM files
Hi Omar,
The presentation slides link point to a PDF file of slides that were used for the webinar video recordings. The SAM file link should point to a .sam file (or .zsam file for older webinars) that you can download and then open using SAM. You will have to download and install SAM to open the SAM files:
sam.nlr.gov/download
- omar mohamud
13 May 2020 18:03 #8198
by omar mohamud
Replied by omar mohamud on topic SAM files
Paul,
I got it. Thank you.
Another question if I may..
I am using Third Party/Developer model and all is good. Except if add a battery to the system and try to charge the battery from PV will not charge if I select "no load data" option. However, if I choose with load, PV is charging the battery. Does "No Load Data" option works with Third Party/Developer model with PV and battery system? Please advice.
I am using SAM 2020 version.
Thanks for the help
Omar
Thanks for the help
Omar
15 May 2020 10:44 #8203
Hi Omar,
Please see my reply to this post:
sam.nlr.gov/forum/forum-general/2998-tpo-developer-model.html
