Combine Cases financial results are zero?
- Mahamoud Mayoo
01 Sep 2021 23:32 #10028
by Mahamoud Mayoo
Replied by Mahamoud Mayoo on topic Combine Cases financial results are zero?
Good morning!
i mew in the forum. i want to simulate hybrid PV / CSP system in SAM, but combining cases in macro does not work, there is always an error message. I do all the combinations of the different models but still no solution. I am using SAM 2020.11.29. I would like to know if it's possible to manually calculate the capacity factor of the hybrid configuration power plant using that of PV and CSP.
best regards
best regards
07 Sep 2021 17:30 #10039
Replied by Paul Gilman on topic Combine Cases financial results are zero?
Hi Mahamoud,
Please try the workaround solution described in this GitHub issue:
github.com/NREL/SAM/issues/282
11 Oct 2021 16:11 #10125
For the Fall 2021 version of SAM, we are replacing the Combine Cases macro with a button on the Power Plant page of the Generic System and Generic Battery models. This will make it easier to combine the generation profiles of different cases in a SAM file (for example Detailed PV and Wind, or PV Battery and Wind, or Detailed PV and Physical Trough).
