Concentrated Solar Power with multijunction cells
- nkabouche
05 Sep 2017 04:49 #4184
by nkabouche
Replied by nkabouche on topic Concentrated Solar Power with multijunction cells
Thank you very much, I found this HCPV module ( www.arima.com.tw/en/group1-detail.php?index_m1_id=1&index_m2_id=2&index_id=28#parentHorizontalTab2 ) but they did not provide the differents losses and error
we have the cell efficiency (>39%) and the module efficiency at STC (27%);
Is it possible to use these value to adjust these factors?
Or do you have these data for an existing cpv module?
Best regards.
Best regards.
05 Sep 2017 15:29 #4185
Replied by Paul Gilman on topic Concentrated Solar Power with multijunction cells
The default module is a good starting point to see what the data should look like. There is not enough information on the Arima data sheet to provide all of the inputs SAM requires, but you may be able to approximate it by using the cell efficiency they report (39%) as the reference efficiency, and adjusting the cell area, number of cells, and loss factors to achieve the maximum power they report.
- nkabouche
07 Sep 2017 03:55 #4186
by nkabouche
Another question is the two axis tracker powered by the HCPV or by an independent source?
is there a bibliographic reference that SAM relies on for HCPV?
Regards.
Regards.
07 Sep 2017 11:55 #4187
SAM assumes that the system is always connected to the grid, and reduces the AC "System power generated" to account for the require tracking power. You can see this by making a copy of your case (click Duplicate on the Case menu), and setting Single tracker power (fraction of DC nameplate) on the Array page to zero. Then run a simulation, and on the Time series tab of the Results page, compare the "AC gross" and "System power generated" values of the two cases to see the impact.
Unfortunately, we do not have documentation of the HCPV model aside from the information in the Help system, and content of discussions on this forum.
- Princess_Zaynab
19 Feb 2018 05:09 #4188
by Princess_Zaynab
Replied by Princess_Zaynab on topic Concentrated Solar Power with multijunction cells
Hello Paul,
I want to ask a question about input "Cell Efficiency".
You are saying that we can have it from a data sheet from the efficiency curve.
When I look at the efficiency curves of the data sheets, efficiency curve is often in function of sun concentration not DNI.
Can we consider that it is the same thing?
Thanks in advance for your answer,
Z
Z
19 Feb 2018 11:44 #4189
Dear Zaynab,
In SAM, you enter the cell efficiency as a function of direct normal irradiance (DNI) in the plane of the module surface, but it also shows you the equivalent sun concentration calculated from the concentration ratio you provide at the top of the input page.
If your data sheet shows efficiency as a function of concentration, you can convert the values to DNI using the following equation:
DNI (W/m2) = Concentration (suns) / Concentration Ratio * 1000 (W/m2/sun)
