Concentrated Solar Power with multijunction cells
01 Mar 2018 10:45 #4196
Replied by Paul Gilman on topic Concentrated Solar Power with multijunction cells
Dear Saeed,
If the datasheet only has the efficiency at one point on the curve, you may need to estimate the efficiency at different irradiances, or you could use a flat curve by using the same efficiency value for all of the irradiance levels.
The packing factor input on the Array page is described in the Help topic for that page. It is a way to account for the cost of land as a function of module area. It is different from the GCR for the PV model, which is used for self-shading calculations. The HCPV model assumes that the trackers are spaced so that there is no self shading.
You can use the Contact page to email me.
- saeedra0
02 Mar 2018 00:11 #4197
by saeedra0
Replied by saeedra0 on topic Concentrated Solar Power with multijunction cells
thank you
