Module Parameters
- njoung
14 Apr 2014 15:36 #2270
by njoung
Module Parameters was created by njoung
How can you see which parameters are required for a specific module? I'm trying to use the pvsandiainv module but I can't figure out what to submit in the data container.
14 Apr 2014 15:46 #2271
Replied by Paul Gilman on topic Module Parameters
I assume you that you are working with the software development kit (SDK) and are asking about the SSC API.
There are two ways to see a list of a module's input parameters, and they are both described in the SDK reference manual (ssc_guide.pdf) that is included in the SDK package.
One way is to use the SDK tool's module browser as described in Section 6.2. Another way is to use the ssc_module_var_info() function as described in Section 3.4.
- njoung
14 Apr 2014 16:56 #2272
by njoung
Replied by njoung on topic Module Parameters
Awesome thank you for the quick response. I actually found that part but a lot of the things that are listed as required for user input don't really make sense so I was worried that I was misunderstanding the output of the function. For example, I ran a modified version of the test script you gave for ssc_module_var_info() on the pv6parmod and it listed DC power output as required. Shouldn't that be an output?
15 Apr 2014 11:28 #2273
Yes, the pv6parmod module's dc variable is an output, and the value of its "required" field is an asterisk, indicating that it is required.
I suspect that all of the output variables have an asterisk for the value of the "required" field because all SSC variables have a "required" field regardless of whether they are input or output variables, the field must have a value, and for output variables, it makes more sense for the value to be required than not required.
Update: The required field for output variables means that the SSC module will always assign it a value. For now, all output variables are "required" (required = *), but we may change that in the future. For example, for the pvsamv1 module, we could make the hourly outputs for subarrays 2-3 not required (required = ?) so that the module only assigns values to those variables when more than one subarray is enabled.
