PySAM simulation time variables
- Aryan
24 Oct 2025 08:14 #14342
by Aryan
PySAM simulation time variables was created by Aryan
Hello Paul,
As I am working to feed vector of mass flow rate to SAM using PySAM, per say for each hour or minute. Can I perform this task using it? And second question is : Can I use sim_start, sim_stop or vaccum_array variables defined in PySAM to perform this task? And will this going to persist the state like if I run plant from 8 to 9 and then 9 to 10 for two different values of mass flow rate, will the state be same in both runs, I mean plant is running from 8 to 10 but with different values of mass flow rate for each hour?
Help me out with this query.
28 Oct 2025 09:40 #14347
Replied by Paul Gilman on topic PySAM simulation time variables
Hi Aryan,
Can you tell me more about what you are trying to model? What compute module(s) are you using and what specific input variables are you modifying?
- Aryan
28 Oct 2025 23:51 #14349
by Aryan
Replied by Aryan on topic PySAM simulation time variables
I am working with Physical Trough Collector Model and I want to give mass flow rate for each hour, or minute. SAM only takes maximum and minimum of it values. But I want to perform above said task, how can I do this?
Help me out!
Thanks!
Help me out!
Thanks!
29 Oct 2025 13:40 #14351
Hi Aryan,
SAM's physical trough model calculates time series mass flow rates and quantities for other system operating parameters based on the design parameter inputs you provide and the operating conditions determined by the weather file data and system component properties. It is not possible to provide time series mass flow rates as input to the model.
- Aryan
31 Oct 2025 08:42 #14359
by Aryan
Can I make changes in code build my custom SAM for this purpose? I have also noticed that we can do that with PySSC. But I don't which file exactly I need to make changes in. Can you help me with this?
31 Oct 2025 16:55 #14360
Hi Aryan,
Making these kinds of fundamental changes to the underlying models is beyond the scope of the support we can provide.
