Discrepancies between SAM and PySAM results
- ALMUDENA MARINA COSTES ALVARGONZÁLEZ
14 Apr 2025 05:58 #13989
by ALMUDENA MARINA COSTES ALVARGONZÁLEZ
Discrepancies between SAM and PySAM results was created by ALMUDENA MARINA COSTES ALVARGONZÁLEZ
Good morning SAM team,
I am using the SAM 2024.12.12 and PySAM 6.0.0, but I have a problem in my code because the results of my SAM do not match with the results in PySAM. I have attached both files. In the results of PySAM, i can see that it can load 125 inputs but in the input browser I have nearly 1000.
When i use my PySAM code, with the default version of SAM, the results in SAM and PySAM match.
Could you help me with the code?
Thanks in advance, and best regards,
Almudena
Almudena
17 Apr 2025 14:59 #13996
Replied by Paul Gilman on topic Discrepancies between SAM and PySAM results
Hi Almudena,
The best way to load inputs to a hybrid configuration from JSON is to use the 'assign()' function. See attached example, which is a modified version of your script.
This should result in the same outputs for SAM 2024.12.12 and PySAM 6.0.1.
