Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
11 Dec 2024 10:56 #13677
Replied by Paul Gilman on topic Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
Hi Jesus,
Thank you for sending the .sam file.
The UTF-8 error is being caused by trying to assign a value to a PySAM variable that does not exist.
The case in your SAM file uses the "PV-Battery / Residential" configuration, which is the same as PySAM's "PVBatteryResidential" configuration. As described in the PySAM documentation for that configuration , this configuration requires the following compute modules:
Belpe
Pvsamv1
Grid
Utilityrate5
Cashloan
When you run SAM's code generator for your .sam file, it generates several JSON files. This one contains inputs for all of the compute modules:
PV_Bat_CIEMAT.json
These contain inputs for each compute module:
PV_Bat_CIEMAT_belpe.json
PV_Bat_CIEMAT_cashloan.json
PV_Bat_CIEMAT_grid.json
PV_Bat_CIEMAT_pvsamv1.json
PV_Bat_CIEMAT_utilityrate5.json
Line 35 of your Python code 'with open(...' reads data from the "PV_Bat_CIEMAT.json" file that contains inputs for all of the compute modules (Belpe, Cashloan, Grid, Pvsamv1 and Utilityrate5).
Line 38 'pv_model=pv.new()' creates a new instance of a Pvsamv1 module.
The For loop starting in Line 43 'for k, v in ...' reads data from the JSON and attempts to assign values to the Pvsamv1 module. When it encounters a variable for Belpe, Cashloan, Grid, or Utilityrate5 it fails because the variable is not valid for Pvsamv1.
To fix this problem, Line 35 should open the "PV_Bat_CIEMAT_pvsamv1.json" file that only contains inputs for the Pvsamv1 module.
Belpe
Pvsamv1
Grid
Utilityrate5
Cashloan
PV_Bat_CIEMAT.json
- Jesús Polo
11 Dec 2024 12:39 #13679
by Jesús Polo
Replied by Jesús Polo on topic Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
Hi Paul
Thanks so much; I finally understood the working mode of the modules; OK I have to read individually the different modules for the objects created by each module; so in case of pv_model I have to read the parameters from the corresponding json file
Now it is clear
Thanks a lot again and best wishes
Jesus
Now it is clear
Jesus
