Pvwattsv8 solar_resouce_data not working
- Isaiah Garcia
19 Jun 2024 20:08 #13269
by Isaiah Garcia
Pvwattsv8 solar_resouce_data not working was created by Isaiah Garcia
Hello! I am currently using PySAM.PSSC and PySAM.Pvwattsv8 and I am running into issues when using solar_resource_data instead of solar_resource_file.
Essentially, I have a weather dataset as a Pandas.dataframe created from this NREL API ( developer.nlr.gov/api/nsrdb/v2/solar/psm3-2-2-download.csv ). Instead of converting that dataframe to csv in my local storage and declaring the solar_resource_file field, I just want to populate solar_resource_data with my weather data.
Here is the specific code block I am using:
When I print out the dc/ac electricity values, I am seeing a list of all 0.0. I tried out the same exact code block replacing solar_resource_data with the solar_resource_file I create, and that works correctly because I am seeing expected outputs.
My main question is if the solar_resource_data is no longer a viable use case for this version of Pvwattsv8?
import PySAM.PySSC as pssc
import PySAM.Pvwattsv8 as pv8
from datetime import datetime, timedelta
start_time = datetime(2022, 1, 1)
time_delta = timedelta(hours=1)
num_hours = 8760
solar_resource_data = {
"lat": info["Latitude"][0],
"lon": info["Longitude"][0],
"tz": info["Time Zone"][0],
"elev": info["Elevation"][0],
"year": [],
"month": [],
"day": [],
"hour": [],
"minute": [30] * num_hours,
# "dn": list(site_generation["DNI"]),
# "df": list(site_generation["DHI"]),
# "gh": list(site_generation["GHI"]),
# "wspd": list(site_generation["Wind Speed"]),
# "tdry": list(site_generation["Temperature"])
"dn": [500]*num_hours, # Example values, replace with actual data
"df": [100]*num_hours, # Example values, replace with actual data
"gh": [600]*num_hours, # Example values, replace with actual data
"wspd": [3]*num_hours, # Example values, replace with actual data
"tdry": [20]*num_hours # Example values, replace with actual data
for hour in range(num_hours):
current_time = start_time + time_delta * hour
solar_resource_data["year"].append(current_time.year)
solar_resource_data["month"].append(current_time.month)
solar_resource_data["day"].append(current_time.day)
solar_resource_data["hour"].append(current_time.hour)
pv_model = pv8.new()
pv_dat = pssc.dict_to_ssc_table(pvwatts_json, "pvwattsv8")
pv_model = pv8.wrap(pv_dat)
pv_model.SolarResource.assign({"solar_resource_data": solar_resource_data})
pv_model.execute()
pv_model.Outputs.dc
20 Jun 2024 12:01 #13270
Replied by Paul Gilman on topic Pvwattsv8 solar_resouce_data not working
Hi Isaiah,
The 'solar_resource_data' variable is an input to the Pvwattsv8 module:
nrel-pysam.readthedocs.io/en/main/modules/Pvwattsv8.html#PySAM.Pvwattsv8.Pvwattsv8.SolarResource.solar_resource_data
Please make sure that your 'pvwatts_json' file does not assign a value to 'solar_resource_file'. The model determines whether to use the weather file or the dictionary based on which variable is assigned: It first checks to see if 'solar_resource_file' is assigned and uses it if assigned, then checks 'solar_resource_data' to see if it is assigned. This means that if the JSON assigns a value to 'solar_resource_file', it will ignore the 'solar_resource_data' variable.
The source code for this behavior is here:
github.com/NREL/ssc/blob/9cadfe3d36a74614a2550065f37388bc8aa2aecf/shared/lib_pv_io_manager.cpp#L125
- Isaiah Garcia
20 Jun 2024 13:08 - 09 Jul 2024 11:31 #13272
by Isaiah Garcia
Replied by Isaiah Garcia on topic Pvwattsv8 solar_resouce_data not working
Thank you for replying! I can confirm that I do not have a 'solar_resource_file' value defined in my pvwatts_json file. I can confirm this by printing out 'PySAM.Pvwattsv8.Pvwattsv8.SolarResource.solar_resource_file' and it gives me an error because it is not assigned (which is what I want).
I can also confirm that my 'solar_resource_data' is properly assigned after I run this line:
My guess at this point is the dictionary is not in the correct format/structure. I attached a link of my example 'solar_resouce_data' dictionary.
Pvwattsv8.SolarResource.assign({'solar_resource_data': solar_resource_data_var})
Last edit: 09 Jul 2024 11:31 by Paul Gilman. Reason: Format code section
24 Jun 2024 09:13 #13274
Hi Isaiah,
Here is some code that I think does what you want:
import json
num_hours = 8760
"lat": 0,
"lon": 0,
"tz": 0,
"elev": 0,
"year": ,
"month": ,
"day": ,
"hour": ,
pv_model = pv8.default("PVWattsNone") # see https://nrel-pysam.readthedocs.io/en/main/sam-configurations.html
print("== Test with no weather data ==")
# model will fail because defaults do not include weather
verbose_simulation = 1
try:
pv_model.execute(verbose_simluation)
except:
print("\npv_model failed")
print("\n== Test with constructed data ==");
# assign resource data constructed above
print("\nDNI from inputs:")
print(pv_model.SolarResource.solar_resource_data["dn"][0:23])
pv_model.execute()
print("\nDC output:")
print(pv_model.Outputs.dc[0:23])
print("\nDNI from outputs:")
print(pv_model.Outputs.dn[0:23])
print("\n== Test with data from JSON ==");
with open( 'example.json', 'r') as f:
pv_inputs = json.load( f )
pv_model.execute()
