Details or Description of various Modules found in SSC SDKtool
- Asif K
20 May 2024 04:47 #13176
by Asif K
Details or Description of various Modules found in SSC SDKtool was created by Asif K
I am new to using SAM and SDKtool. I am able to use a module "iph_to_lcoefcr" and run a program in visual studiio / c#. It worls perfect. Perhaps this is one of the smallest module in SDK. NOw, I am looking to use other modules shown in SDKtool. however, as of first step, I need to understand or to have some sort of descritption of all other modules.
Lets say, I am interested to use a model available in SAM software i.e. PVWatts/ Distributed / Residential Owner, then question is it relates to which module shown in the SDKTool.
THanks
THanks
20 May 2024 15:49 #13181
Replied by Paul Gilman on topic Details or Description of various Modules found in SSC SDKtool
Hi Asif,
For reference, the SAM SDK is described here: sam.nlr.gov/software-development-kit-sdk .
The SSC modules are not documented, aside from whatever comments exist in the code, and the brief description in the DEFINE_MODULE_ENTRY() function at the end of the C++ file for each module, for example here for the iph_to_lcoefcr module you mention:
github.com/NREL/ssc/blob/patch/ssc/cmod_iph_to_lcoefcr.cpp
PySAM is a Python wrapper that is available as a Python package with slightly better documentation of the SSC modules:
nrel-pysam.readthedocs.io/en/main/ssc-modules.html
The PySAM documentation also lists the model configurations that are available in the SAM user interface here:
nrel-pysam.readthedocs.io/en/main/sam-configurations.html
- Asif K
20 May 2024 23:23 #13183
by Asif K
Replied by Asif K on topic Details or Description of various Modules found in SSC SDKtool
Hi Paul
Thanks for the quick response. Appreciated !!
Could you please inform which module in SDQtool relate to following Models in SAM software:
1) Photovoltaic / Detailed PV Model / Distributed / Residential Owner2) Photovoltaic / Detailed PV Model / Distributed / No Financial Model
21 May 2024 10:24 #13185
Hi Asif,
Detailed PV / Residential ( nrel-pysam.readthedocs.io/en/main/sam-configurations.html#detailed-pv-model-residential-owner ): belpe, pvsamv1, grid, utilityrate5, cashloan
Detailed PV/ No Financial ( nrel-pysam.readthedocs.io/en/main/sam-configurations.html#detailed-pv-model-no-financial-model ): pvsamv1, grid
