No module named 'PySAM'
- Zhaoyun Zeng
15 Apr 2024 08:28 #13082
by Zhaoyun Zeng
No module named 'PySAM' was created by Zhaoyun Zeng
I have successfully installed PySAM. By typing "pip list", I can see:
NREL-PySAM 5.1.0
NREL-PySAM-stubs 3.0.1
However, when I tried to run the following:
import PySAM.Pvsamv1 as pv
I got:
ModuleNotFoundError: No module named 'PySAM'
How can I solve this problem?
Zhaoyun
NREL-PySAM 5.1.0
I got:
Zhaoyun
15 Apr 2024 10:11 #13083
Replied by Paul Gilman on topic No module named 'PySAM'
Hi Zhaoyun,
I think this is because of your Python environment. Perhaps you have more than one version of Python installed, or are running your script in a virtual environment that does not have access to the PySAM package you installed.
Please try searching the web for "ModuleNotFoundError" to see if you can find a solution.
- Zhaoyun Zeng
15 Apr 2024 12:56 #13085
by Zhaoyun Zeng
Replied by Zhaoyun Zeng on topic No module named 'PySAM'
Thanks for the quick response. Yes, your guess is correct.
My usual python installation directory is C:\Users\ladmin\AppData\Local\Programs\Python\Python311\Lib\site-packages. However, NREL-PySAM was installed in C:\Users\ladmin\AppData\Roaming\Python\Python312\site-packages. I used the same VS Code terminal to install PySAM. I don't why it is installed in the wrong directory. Do you know how to solve it?
Zhaoyun
Zhaoyun
17 Apr 2024 13:49 #13096
Hi Zhaoyun,
You may want to set up Python virtual environment to manage your Python installation and packages. Some options are Python's `venv` or Anaconda's `conda`.
