Parabolic Trough - Physical - IAM formula
- Paulo
20 Mar 2024 17:04 #13007
by Paulo
Parabolic Trough - Physical - IAM formula was created by Paulo
Hello, I am running some simulations with the Parabolic Trough model and I would like to know:
(1) the formula for the IAM in the Parabolic Trough (Physical) model and
(2) how the efficiency of the collector is calculated (loss method?)
Doc Page: nrel-pysam.readthedocs.io/en/latest/modules/TroughPhysical.html
Variable: IAM_matrix
Description: IAM coefficients, matrix for 4 collectors
Default Values SAM GUI: 1, 0.0327, -0.1351
Many thanks!
Many thanks!
21 Mar 2024 10:06 #13016
Replied by Paul Gilman on topic Parabolic Trough - Physical - IAM formula
Hi Paolo,
The IAM_matrix variable is equivalent to the "Incidence angle modifier coefficients" input on the Collectors (SCA) page in SAM. This is an input. You can see how the model calculates the incidence angle modifier (IAM) from the coefficients in the source code on GitHub:
github.com/NREL/ssc/blob/990f351727867f7d71dcec1705cfa74dca8750b9/ssc/cmod_csp_common_eqns.cpp#L1044
The collector optical efficiency calculations are here:
github.com/NREL/ssc/blob/990f351727867f7d71dcec1705cfa74dca8750b9/tcs/csp_solver_trough_collector_receiver.cpp#L4357
