LK vs. Python?
- dpinney
04 Mar 2013 11:31 #1385
by dpinney
LK vs. Python? was created by dpinney
Hello forum, quick novice question: is there any SAM SDK functionality that can only be accessed via the LK scripting language, or can I do everything in Python?
04 Mar 2013 17:01 #1386
Replied by Paul Gilman on topic LK vs. Python?
You can access the full functionality of the SSC libraries n the software development kit (SDK) from either LK or Python.
LK works from the SSCdev developer interface. The benefit of working with LK in SSCdev is that you can use the module browser and data container to explore the module variables in easy-to-read tables. (You can get the same information in Python using the appropriate functions.) One approach to getting started with the SDK might be to work with LK in SSCdev to familiarize yourself with the SSC modules and to test your algorithms, and then to implement the algorithm in Python (or one of the other languages supported in the SDK) once you are comfortable that it works.
- dpinney
05 Mar 2013 09:16 #1387
by dpinney
Replied by dpinney on topic LK vs. Python?
Thanks Paul, I appreciate the detailed answer. I'll give LK in SSCDev a shot.
