Converting nestle tuple 0 into row in matrix
- Martineau
10 Jul 2023 00:55 #12298
by Martineau
Converting nestle tuple 0 into row in matrix was created by Martineau
Hello everyone,
I'm trying to make a code to simulate wind turbine with PySAM, but I have a problem, I can't execute the code.
Here is the code that i've made :
import PySAM.Windpower as wp
import csv
# Create a Windpower object
wind_turbine = wp.default("WindPowerSingleOwner")
# Set the turbine parameters
wind_turbine.system_capacity = 200 # Turbine capacity in kW
wind_turbine.max_cp = 0.45 # Maximum power coefficient
wind_turbine.max_tip_speed = 80 # Maximum tip speed in m/s
wind_turbine.cut_in_speed = 3 # Cut-in wind speed in m/s
wind_turbine.cut_out_speed = 25 # Cut-out wind speed in m/s
def csv_to_dict(file_path):
result_dict = {}
with open(file_path, 'r') as csvfile:
reader = csv.DictReader(csvfile)
for row in reader:
val = float(row)
try:
perc = float(row)
except ValueError:
perc = None
try:
sel_perc = float(row)
except ValueError:
sel_perc = None
result_dict[val] = (perc, sel_perc)
return result_dict
# Provide the file path to your CSV file
csv_file_path = 'C:/Users/arthu/OneDrive/Documents/INTERNSHIP/SAM/05-07-2023/windSpeed.csv'
# Convert the CSV file to a dictionary
data_dict = csv_to_dict(csv_file_path)
# Print the values of data_dict
for key, value in data_dict.items():
print(f"Key: {key}, Value: {value}")
# Construct the wind resource data dictionary
wind_resource_data = {
'fields': ,
'heights': [0],
'val': [key for key in data_dict.keys()],
'perc': [data_dict[key][0] for key in data_dict.keys() if data_dict[key][0] is not None],
'sel_perc': [data_dict[key][1] for key in data_dict.keys() if data_dict[key][1] is not None]
# Print the wind resource data dictionary
print("Wind Resource Data:")
print(wind_resource_data)
# Set the wind resource data
wind_turbine.Resource.wind_resource_data = wind_resource_data
# Run the simulation
wind_turbine.execute()
# Access the wind turbine outputs
annual_energy = wind_turbine.Outputs.annual_energy
# Print the annual energy production
print("Annual Energy Production:", annual_energy, "kWh")
When I execute this program, it display the error message : Cell In[39], line 55
52 print(wind_resource_data)
54 # Set the wind resource data
---> 55 wind_turbine.Resource.wind_resource_data = wind_resource_data
57 # Run the simulation
58 wind_turbine.execute()
Exception: Error (-4) converting nested tuple 0 into row in matrix.
I don't know what this error message means
I've tried several solution like change the file path but it's not working.
I have attached the CSV file.
I will be very glad if someone could help me
import csv
result_dict = {}
for row in reader:
val = float(row)
try:
perc = float(row)
except ValueError:
perc = None
try:
except ValueError:
sel_perc = None
return result_dict
'fields': ,
'heights': [0],
12 Jul 2023 10:26 #12315
Replied by Paul Gilman on topic Converting nestle tuple 0 into row in matrix
Hi Martineau,
I was not able to test your script because of a syntax error in the construction of 'wind_resource_data'.
