Nonsensical values battery stateful
05 May 2023 11:49 #12119
Replied by Paul Gilman on topic Nonsensical values battery stateful
Hi Anton,
What kind of Mac are you using? We do run PySAM on Mac computers -- it should work on Windows, Mac, and Linux. I have heard from SAM desktop application users having some trouble with the new MacBook Pro with the M2 chip.
There are some code examples in the PySAM code repository using Jupyter notebooks: github.com/NREL/pysam/tree/main/Examples .
- Anton Szilasi
09 May 2023 19:15 - 10 May 2023 11:44 #12134
by Anton Szilasi
Replied by Anton Szilasi on topic Nonsensical values battery stateful
Last edit: 10 May 2023 11:44 by Paul Gilman.
11 May 2023 11:26 #12142
Hi Anton,
We have been able to reproduce this issue on a MacBook Pro with the M1 Max chip and in a Debian 11 aarch64 Docker container.
Running your script in a Debian 11 amd64 (x86_64) Docker container generates results consistent with those in Windows.
This is a problem we will fix, but for now, you can use a Docker amd64 container to run your script. See this GitHub issue to track our progress: github.com/NREL/ssc/issues/1023
Thank you for bringing this to our attention.
- Anton Szilasi
21 May 2023 18:15 #12162
by Anton Szilasi
Thank you for addressing this quickly I do appreciate it. I see that the PR has been merged now does that mean that this fix is in production with nrel-pysam 4.1.0?
If not how do I access this fix? Or when will it be available?
Regards.
Anton
Regards.
Anton
23 May 2023 10:57 #12169
Hi Anton,
This should be available in the update that follows PySAM 4.1.0 (I think that will be 4.2.0). We are working on that update now, and should release it within the next week or so.
- Anton Szilasi
01 Jun 2023 17:03 #12194
by Anton Szilasi
Any update on this release?
Having this bug fixed would be super helpful for me as switching over to a different cpu architecture is a bit tricky for me.
Anton
Anton
