Retrieving hourly system power generated (kW) using PySSC
- Colleen
06 Apr 2023 23:32 #12039
by Colleen
Retrieving hourly system power generated (kW) using PySSC was created by Colleen
Hello!
My team and I are using the PySAM and PySSC libraries to request WIND Toolkit Data inputs and run a simulation to return hourly energy and capacity factors for several coordinate pairs iteratively. Our WIND Toolkit Data input (.srw file) is in hourly time series. However, we run into the issue that we cannot retrieve these hourly parameters other than their annual averages.
Our goal is to retrieve the hourly system power generated (kw) for each hour since Jan 1 within a pandas dataframe. Are there example Python scripts/notebooks of how we could retrieve an this hourly system power generated (kw) and capacity factor with PySam using PySSC?
For some additional context here are some snippets of our code of creating the ssc objects and retrieving the average annual data.
import PySAM
from PySAM.PySSC import PySSC
ssc = PySSC()
lat_in = a provided latitude
lon_in = a provided longitude
## =====> ADDED TO READ DATA FROM Windtoolkit
# Resource inputs for SAM model: ## need to add b
wfd = ssc.data_create()
ssc.data_set_number(wfd, b'lat', lat_in)
ssc.data_set_number(wfd, b'lon', lon_in)
# Create SAM compliant object
data = ssc.data_create()
ssc.data_set_table(data, b'wind_resource_data', wfd)
ssc.data_free(wfd)
- Code from the SAM Code Generator -
# leaving this code out of this question to reduce code length
module = ssc.module_create(b'windpower')
ssc.module_exec_set_print( 0 );
if ssc.module_exec(module, data) == 0:
print ('windpower simulation error')
idx = 1
msg = ssc.module_log(module, 0)
while (msg != None):
print (' : ' + msg.decode("utf - 8"))
msg = ssc.module_log(module, idx)
idx = idx + 1
SystemExit( "Simulation Error" );
ssc.module_free(module)
module = ssc.module_create(b'grid')
print ('grid simulation error')
idx = 1
idx = idx + 1
annual_energy = ssc.data_get_number(data, b'annual_energy');
print ('Annual AC energy in Year 1 = ', annual_energy)
capacity_factor = ssc.data_get_number(data, b'capacity_factor');
print ('Capacity factor in Year 1 = ', capacity_factor)
ssc.data_free(data);
import PySAM
ssc = PySSC()
ssc.data_free(wfd)
idx = 1
idx = idx + 1
idx = 1
idx = idx + 1
07 Apr 2023 16:57 - 07 Apr 2023 16:58 #12045
Replied by Paul Gilman on topic Retrieving hourly system power generated (kW) using PySSC
Hi Colleen,
The 'gen' output variable stores the hourly ac output of the system. The following code should get that data for you:
hourly_energy = ssc.data_get_array(data, b'gen');
Last edit: 07 Apr 2023 16:58 by Paul Gilman.
- Colleen
11 Apr 2023 20:59 #12052
by Colleen
Replied by Colleen on topic Retrieving hourly system power generated (kW) using PySSC
Thank you for providing this information! It works great and we are able to move forward with collecting the timeseries data.
Best,
Colleen McCamy
Best,
Colleen McCamy
