pvwattsv8 execution error. exec fail(pvwatsv8): Minute column required
- Eric H
09 Jan 2023 14:40 #11813
by Eric H
pvwattsv8 execution error. exec fail(pvwatsv8): Minute column required was created by Eric H
I am getting an error using pvwattsv8 when using self defined weather data.
I have made sure all the weather data length are 8760.
the error I am getting is
import PySAM.Pvwattsv8 as pv8
PVWATTSNONE = pv8.default('PVWattsNone')
def sam_pvwatts8(system_capacity=1, tilt=None, losses=0.2, array_type=0,
GHI=None, DNI=None, DHI=None, lat=None, lon=None, temp=None,
wind_speed=None, time_zone_UTC=None, elev=None, albedo=None,
filename=None, **kwargs):
pv_model = pv.new()
pv_model.SystemDesign.assign(PVWATTSNONE.SystemDesign.export())
pv_model.AdjustmentFactors.assign(PVWATTSNONE.AdjustmentFactors.export())
if albedo is None:
albedo = np.full(8760, 0.2)
# print('creating solar_resource_data')
solar_resource_data = {'solar_resource_data':
{'lat': lat,
'lon': lon,
'tz': time_zone_UTC,
'tdry': tuple(temp),
'alb': tuple(albedo),
'wspd': tuple(wind_speed),
'dn': tuple(DNI),
'df': tuple(DHI),
'gh': tuple(GHI)}}
if not (elev is None):
solar_resource_data['solar_resource_data']['elev'] = elev
# print('assigning locationandresource data')
pv_model.LocationAndResource.assign(solar_resource_data)
if tilt is None:
tilt = lat
# print('assigning systemdesign data')
# add tilt and losses to kwargs dictionary
kwargs['system_capacity'] = system_capacity
# print(tilt)
kwargs['tilt'] = tilt
kwargs['losses'] = 100*losses
kwargs['array_type'] = array_type
# convert losses to percentage. is passed in as decimal to be
# consistent with wind power function.
pv_model.SystemDesign.assign(kwargs)
# print('before execute')
pv_model.execute()
return pv_model
pvwattsv8 execution error. exec fail(pvwatsv8): Minute column required in weather data for subhourly data or data that is not continuous over one year.
10 Jan 2023 10:51 #11821
Replied by Paul Gilman on topic pvwattsv8 execution error. exec fail(pvwatsv8): Minute column required
Hi Eric,
If your weather data has fewer or more than 8760 hourly records, you should provide year, month, day, hour, and minute values for each time step. The pvwattsv8 module uses these values for sun angle calculations.
- Eric H
10 Jan 2023 12:27 #11824
by Eric H
Replied by Eric H on topic pvwattsv8 execution error. exec fail(pvwatsv8): Minute column required
is there a format the year, month, day, hour, and minute needs to be?
I am now getting this error
I am creating those data here:
compute fail(pvwattsv8): hour_of_year input month, day, or hour out of correct range for m-d-h: 1=0-0
time = pd.DatetimeIndex(pd.date_range(start=f'2019-01-01', end='2019-12-31 23:00', freq='H'))solar_resource_data = {'solar_resource_data':
{'lat': lat,
'lon': lon,
'dn': tuple(DNI),
'df': tuple(DHI),
'gh': tuple(GHI)
'year': time.year,
'month': time.month,
'day': time.day,
'hour': time.hour,
'minute': time.minute
11 Jan 2023 15:17 #11826
Hi Eric,
Those time stamp inputs also need to be tuples. See this example:
github.com/NREL/pysam/blob/master/Examples/NonAnnualSimulation.ipynb
