How to add a new subarray on a lk script and how to save the results
- Gabriel Simões
27 Oct 2022 13:19 #11610
by Gabriel Simões
How to add a new subarray on a lk script and how to save the results was created by Gabriel Simões
Hi SAM team.
First doubt:
I've generated a lk script from the system I've modeled on SAM, and I wonder if it is possible to add a fifth subarray. I inserted the variables for this fifth subarray just copying the data from subarray 2 but the results didn't change.
Second doubt:
I would like to know if it is possible to save the hourly/sub-hourly results in a csv file. The aim of this lk script is simulate to many meteo files, but i would like to save the final results.
here's the part of the code with the fifth subarray:
var( 'subarray1_nstrings', 214 );
var( 'subarray1_modules_per_string', 36 );
var( 'subarray1_mppt_input', 1 );
var( 'subarray1_tilt', 0 );
var( 'subarray1_tilt_eq_lat', 0 );
var( 'subarray1_azimuth', 0 );
var( 'subarray1_track_mode', 1 );
var( 'subarray1_rotlim', 60 );
var( 'subarray1_shade_mode', 1 );
var( 'subarray1_gcr', 0.34999999999999998 );
var( 'subarray1_slope_tilt', 0 );
var( 'subarray1_slope_azm', 0 );
var( 'subarray1_monthly_tilt', [ 40, 40, 40, 20, 20, 20, 20, 20, 20, 40, 40, 40 ] );
var( 'subarray1_soiling', [ 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5 ] );
var( 'subarray1_rear_irradiance_loss', 3 );
var( 'subarray1_mismatch_loss', 0 );
var( 'subarray1_diodeconn_loss', 0 );
var( 'subarray1_dcwiring_loss', 2 );
var( 'subarray1_tracking_loss', 0 );
var( 'subarray1_nameplate_loss', 0 );
var( 'subarray2_rear_irradiance_loss', 3 );
var( 'subarray2_mismatch_loss', 0 );
var( 'subarray2_diodeconn_loss', 0 );
var( 'subarray2_dcwiring_loss', 2 );
var( 'subarray2_tracking_loss', 0 );
var( 'subarray2_nameplate_loss', 0 );
var( 'subarray3_rear_irradiance_loss', 0 );
var( 'subarray3_mismatch_loss', 2 );
var( 'subarray3_diodeconn_loss', 0.5 );
var( 'subarray3_dcwiring_loss', 2 );
var( 'subarray3_tracking_loss', 0 );
var( 'subarray3_nameplate_loss', 0 );
var( 'subarray4_rear_irradiance_loss', 0 );
var( 'subarray4_mismatch_loss', 2 );
var( 'subarray4_diodeconn_loss', 0.5 );
var( 'subarray4_dcwiring_loss', 2 );
var( 'subarray4_tracking_loss', 0 );
var( 'subarray4_nameplate_loss', 0 );
var( 'subarray5_rear_irradiance_loss', 3 );
var( 'subarray5_mismatch_loss', 0 );
var( 'subarray5_diodeconn_loss', 0 );
var( 'subarray5_dcwiring_loss', 2 );
var( 'subarray5_tracking_loss', 0 );
var( 'subarray5_nameplate_loss', 0 );
var( 'dcoptimizer_loss', 0 );
var( 'acwiring_loss', 1 );
var( 'transmission_loss', 0 );
var( 'subarray1_mod_orient', 0 );
var( 'subarray1_nmodx', 36 );
var( 'subarray1_nmody', 2 );
var( 'subarray1_backtrack', 1 );
var( 'subarray2_enable', 1 );
var( 'subarray2_modules_per_string', 36 );
var( 'subarray2_nstrings', 214 );
var( 'subarray2_mppt_input', 1 );
var( 'subarray2_tilt', 0 );
var( 'subarray2_tilt_eq_lat', 0 );
var( 'subarray2_azimuth', 0 );
var( 'subarray2_track_mode', 1 );
var( 'subarray2_rotlim', 60 );
var( 'subarray2_shade_mode', 1 );
var( 'subarray2_gcr', 0.34999999999999998 );
var( 'subarray2_slope_tilt', 0 );
var( 'subarray2_slope_azm', 0 );
var( 'subarray2_monthly_tilt', [ 40, 40, 40, 20, 20, 20, 20, 20, 20, 40, 40, 40 ] );
var( 'subarray2_soiling', [ 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5 ] );
var( 'subarray2_mod_orient', 0 );
var( 'subarray2_nmodx', 36 );
var( 'subarray2_nmody', 2 );
var( 'subarray2_backtrack', 1 );
var( 'subarray3_enable', 0 );
var( 'subarray3_modules_per_string', 0 );
var( 'subarray3_nstrings', 0 );
var( 'subarray3_mppt_input', 1 );
var( 'subarray3_tilt', 20 );
var( 'subarray3_tilt_eq_lat', 0 );
var( 'subarray3_azimuth', 180 );
var( 'subarray3_track_mode', 0 );
var( 'subarray3_rotlim', 45 );
var( 'subarray3_shade_mode', 0 );
var( 'subarray3_gcr', 0.29999999999999999 );
var( 'subarray3_slope_tilt', 0 );
var( 'subarray3_slope_azm', 0 );
var( 'subarray3_monthly_tilt', [ 40, 40, 40, 20, 20, 20, 20, 20, 20, 40, 40, 40 ] );
var( 'subarray3_soiling', [ 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5 ] );
var( 'subarray3_mod_orient', 0 );
var( 'subarray3_nmodx', 9 );
var( 'subarray3_nmody', 2 );
var( 'subarray3_backtrack', 0 );
var( 'subarray4_enable', 0 );
var( 'subarray4_modules_per_string', 0 );
var( 'subarray4_nstrings', 0 );
var( 'subarray4_mppt_input', 1 );
var( 'subarray4_tilt', 20 );
var( 'subarray4_tilt_eq_lat', 0 );
var( 'subarray4_azimuth', 180 );
var( 'subarray4_track_mode', 0 );
var( 'subarray4_rotlim', 45 );
var( 'subarray4_shade_mode', 0 );
var( 'subarray4_gcr', 0.29999999999999999 );
var( 'subarray4_slope_tilt', 0 );
var( 'subarray4_slope_azm', 0 );
var( 'subarray4_monthly_tilt', [ 40, 40, 40, 20, 20, 20, 20, 20, 20, 40, 40, 40 ] );
var( 'subarray4_soiling', [ 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5 ] );
var( 'subarray4_mod_orient', 0 );
var( 'subarray4_nmodx', 9 );
var( 'subarray4_nmody', 2 );
var( 'subarray4_backtrack', 0 );
var( 'subarray5_enable', 1 );
var( 'subarray5_modules_per_string', 36 );
var( 'subarray5_nstrings', 214 );
var( 'subarray5_mppt_input', 1 );
var( 'subarray5_tilt', 0 );
var( 'subarray5_tilt_eq_lat', 0 );
var( 'subarray5_azimuth', 0 );
var( 'subarray5_track_mode', 1 );
var( 'subarray5_rotlim', 60 );
var( 'subarray5_shade_mode', 1 );
var( 'subarray5_gcr', 0.34999999999999998 );
var( 'subarray5_slope_tilt', 0 );
var( 'subarray5_slope_azm', 0 );
var( 'subarray5_monthly_tilt', [ 40, 40, 40, 20, 20, 20, 20, 20, 20, 40, 40, 40 ] );
var( 'subarray5_soiling', [ 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5, 2.5 ] );
var( 'subarray5_mod_orient', 0 );
var( 'subarray5_nmodx', 36 );
var( 'subarray5_nmody', 2 );
var( 'subarray5_backtrack', 1 );
Best regards
Gabriel
First doubt:
Second doubt:
Best regards
Gabriel
31 Oct 2022 12:11 #11622
Replied by Paul Gilman on topic How to add a new subarray on a lk script and how to save the results
Hi Gabriel,
SAM's Detailed PV model (pvsamv1) is limited to four subarrays. It is not possible to add a fifth subarray.
You can use the csvwrite() function to save time series data to CSV. See the csv-functions.lk example file on GitHub here github.com/NREL/SAM/tree/develop/samples/LK%20Scripts%20for%20SAM .
- Gabriel Simões
02 Nov 2022 12:06 #11633
by Gabriel Simões
Replied by Gabriel Simões on topic How to add a new subarray on a lk script and how to save the results
Thks so much, Paul.
Best regards
Best regards
