thread workers parameter in PySAM ResourceTools.FetchResourceFiles
- Greg Miller
03 Dec 2021 15:24 #10337
by Greg Miller
thread workers parameter in PySAM ResourceTools.FetchResourceFiles was created by Greg Miller
The PySAM ResourceTools.FetchResourceFiles function has a parameter called "workers", which allows you to specify the number of threads to use when parellelizing downloads (
nrel-pysam.readthedocs.io/en/master/Tools.html?highlight=workers#files.ResourceTools.FetchResourceFiles
I'm looking to allow this parameter to be dynamically defined on the user's machine depending on the capability of the machine to run parallel downloads. My question is whether parallelized downloads depends on the number of CPU threads on the machine, or if it is related to some other parameter about the computer or network.
Say one is trying to download hundreds of resource files - how would you suggest setting the workers parameter to maximize parallelization? In other words, what is the upper limit on the number of workers that can run in parallel?
Thank you!
Thank you!
07 Dec 2021 09:54 #10350
Replied by Paul Gilman on topic thread workers parameter in PySAM ResourceTools.FetchResourceFiles
Hi Greg,
The NSRDB API rate limits are likely to be more of a constraint than your machine's speed. See this NSRDB API guide for information about those limits: developer.nlr.gov/docs/solar/nsrdb/guide/ . You'll have to do a few test downloads to see what parallelization settings result in the speeds you want.
The functions in FetchResourceFiles are designed to download a single file at a time. The guide describes how to download sets of files. You might want to fork off of ResourceTools.py to make modifications for requests of sets of files rather than a single one.
