Heat Transfer Fluid Type (ID) in PySAM
- Marcelo Fernandes
20 Oct 2020 10:17 #8901
by Marcelo Fernandes
Heat Transfer Fluid Type (ID) in PySAM was created by Marcelo Fernandes
Hi all,
I have been using PySAM for my research work and had a question about the type of heat transfer fluids (HTFs) and their IDs. I have not been able to find which fluid ID corresponds to which HTF in the documentation and was wondering if you'd be able to help me.
Here are a few locations where this variable is used in PySAM:
Marcelo
- nrel-pysam.readthedocs.io/en/master/modules/TroughPhysicalProcessHeat.html?highlight=Type%20of%20heat%20transfer%20fluid#PySAM.TroughPhysicalProcessHeat.TroughPhysicalProcessHeat.SolarField.Fluid
- nrel-pysam.readthedocs.io/en/master/modules/TroughPhysical.html?highlight=Type%20of%20heat%20transfer%20fluid#PySAM.TroughPhysical.TroughPhysical.SolarField.Fluid
- nrel-pysam.readthedocs.io/en/master/modules/TcstroughEmpirical.html?highlight=Type%20of%20heat%20transfer%20fluid#PySAM.TcstroughEmpirical.TcstroughEmpirical.Solarfield.HTFFluid
Marcelo
20 Oct 2020 11:23 #8904
Replied by Paul Gilman on topic Heat Transfer Fluid Type (ID) in PySAM
Hi Marcelo,
You can determine the index for an HTF by looking at the SAM user interface.
For example, on the Solar Field page for the Physical Trough model, the Field HTF fluid (combo_htf_type) input is this dropdown list,
so combo_htf_type = 3 is the Therminol VP-1 HTF:
There is code in the user interface that translates combo_htf_type into a value for the SSC variable Fluid, so for Therminol VP-1,
you would set Fluid = 21:
Another, more useful reference might be the comment block in materials.cpp in the SAM GitHub repository, which is a complete list of all of the Fluid ID values:
github.com/NREL/SAM/blob/c6f570b48f35ace11590b95fedf14216996d6598/src/materials.cpp#L298 .
equations{ 'Fluid' } = define() {
return ?${combo_htf_type}
18, // 18.) Nitrate Salt**
19, // 19.) Caloria HT 43**
20, // 20.) Hitec XL**
21, // 21.) Therminol VP-1**
22, // 22.) Hitec**
23, // 23.) Dowtherm Q**
24, // 24.) Dowtherm RP**
30, // 30.) Therminol 59
29, // 29.) Therminol 66
31, // 31.) Pressurized Water
50 // user defined HTF
- Marcelo Fernandes
20 Oct 2020 13:01 #8907
Replied by Marcelo Fernandes on topic Heat Transfer Fluid Type (ID) in PySAM
That's an excellent answer, Paul! Thank you
