setting LK array values from text strings
- kaiyer
04 Jul 2020 13:25 #8390
by kaiyer
setting LK array values from text strings was created by kaiyer
For example, after using the inputs browser in SAM to export values to CSV we have utility PBI as follows
We can read that back into LK as a string
pbi_uti_amount = "10;11;12;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0";
I am looking for a code snippet that will take this string, parse it and set the array value in SAM
sam_set_inputs('pbi_uti_amount', arr).
I'm looking for a code snippet that can initialize arr from values in pbi_uti_amount.
Any help greatly appreciated!
| pbi_uti_amount | Utility PBI amount | 10;11;12;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0 |
06 Jul 2020 09:50 - 06 Jul 2020 09:50 #8401
Replied by Paul Gilman on topic setting LK array values from text strings
Hi Kaiyer,
The PBI amount and other inputs that appear in the SAM user interface with the "Sched/Value" blue and grey buttons are arrays. If the array has one element, SAM interprets the value as a Year 1 value and applies inflation to calculate values in Years 2 and later. If the array has more than one element, it treats each value as a nominal value in each year. If the array is longer than the analysis period, SAM truncates the array length to the analysis period. If the array is shorter than the analysis period, SAM assigns the value zero to years with no values.
Here is some LK code that reads the string you provided, converts to an array and assigns the array's value to pbi_uti_amount. It also runs a simulation and shows the PBI amount from the resulting cashflow so you can verify that it works:
outln( get('pbi_uti_amount') );
str = "10;11;12;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0";
outln(str);
arr = split(str,';');
outln(arr);
set('pbi_uti_amount',arr);
simulate();
outln( get('cf_pbi_total_uti') );
Last edit: 06 Jul 2020 09:50 by Paul Gilman.
