Why doesn't PySAM give me the same results the GUI does?
  • Rob Frohne
  • Topic Author
18 Feb 2020 01:20 #7983 by Rob Frohne
I'm trying to reproduce the results I get with the 2020.1.17 GUI using PVWatts in PySAM.  I am finding differences, though some things are the as I expect.  Here are two differences I'm trying to figure out:
  1.  The PVWattsv7.Outputs.ac_annual should be 134580kWh according to the GUI, but I get 137318kWh from PySAM.
  2.  The net present value should be $113,624, but PySAM is giving mo $494,922.
I'm including the python script, and a .sam file.  You have to save the .json file from SAM, and then using the python script select it.
Do you have any tips?
Rob
File Attachment:
File Name: PySAM_tests.sam
File Size:154.9 KB
File Attachment:
File Name: LEAC.py
File Size:1.36 KB
  • Rob Frohne
  • Topic Author
19 Feb 2020 01:01 #7987 by Rob Frohne
Today, I thought that the thing I am doing wrong is that I'm using the PVWatts7 and the SingleOwner in PySAM, but I'm doing PVWatts7 Commercial in SAM.  So I went to try and add the utilityrate5 and cashloan in instead of just going to the single owner directly.  Eventually I need to modify the utility rates anyway.  Now, I have an issues where it is segmentation faulting.  I don't know if this is because I'm just following the pattern that worked before or what.  Here is the script with those changes. Do you have any ideas?
Rob
File Attachment:
File Name: LEAC_2020-02-19.py
File Size:1.96 KB
Powered by Kunena Forum
