CSP generic with Python 3
- gorman_will
28 Jan 2020 18:19 #7911
by gorman_will
CSP generic with Python 3 was created by gorman_will
I am trying to run a loop of CSP plants using SDK and python. I have generated the code via SAM, and believe I have set up the model correctly (i.e. don't get an error when running "mod = ssc.module_create(b'tcsgeneric_solar')" and "ssc.module_exec(mod, dat)"
However, I can't appear to extract an hourly profile from my results. I am using the same command I use when running the pvwatts model: np.array(ssc.data_get_array(dat, b'gen'))
But nothing appears to be in that array. Is there a different command to get the hourly AC electricity output from the CSP module?
Thank you for any help!!
03 Feb 2020 15:36 - 03 Feb 2020 15:38 #7930
Replied by Paul Gilman on topic CSP generic with Python 3
Hi Will,
The variable name for the time series output of the system is "gen", so I would expect your method to work.
If everything is set up correctly, you should see reasonable values for the variables "annual_energy" and "capacity_factor".
Also, PySAM might be helpful if you are using Python to interact with SSC:
sam.nlr.gov/software-development-kit-sdk/pysam.html
Last edit: 03 Feb 2020 15:38 by Paul Gilman.
