Accessing windpower module output in Python
- Angus King
02 Jan 2019 04:10 #6575
by Angus King
Accessing windpower module output in Python was created by Angus King
I've recently noticed that retrieving the 'gen' array - Total electric power to grid' is much slower than earlier releases of the SDK. The change actually occurred somewhere between Build 174 and 180. Is there a better way to access this data or is it due to some internal change?
I'm using Python 2.7 and the relevant code is:
Build 174 and prior would take about 2 seconds to execute the module and retrieve the data and it's now around 14 seconds. Below is a small execution log for two runs:
Kind regards
Angus
clock_start = time.clock()
module = ssc.Module('windpower')
print time.clock() - clock_start
farmpwr = self.data.get_array('gen')
22:38:23. SAM SDK Core: Version = 174. Build info = Linux 64 bit GNU/C++ Jun 19 2017 05:06:12.
22:38:32. Processing Collgar Wind Farm
22:38:32. (0.000110 seconds)
22:38:34. (1.951400 seconds)
22:39:03. Power plot completed for Collgar Wind Farm. 568,148.0 MWh; CF 0.31
22:48:52. SAM SDK Core: Version = 180. Build info = Linux 64 bit GNU/C++ Oct 30 2017 03:52:08.
22:49:05. Processing Collgar Wind Farm
22:49:05. (0.000062 seconds)
22:49:19. (14.434305 seconds)
22:49:26. Power plot completed for Collgar Wind Farm. 573,984.0 MWh; CF 0.32
Kind regards
Angus
04 Jan 2019 14:51 #6576
Replied by Paul Gilman on topic Accessing windpower module output in Python
Dear Angus,
We've fixed this problem. Thank you for pointing it out. For more on the problem, see:
github.com/NREL/ssc/issues/222
