Notices, warnings, errors from SDK
- Unknown User
05 Jun 2017 04:52 #5495
by Unknown User
Notices, warnings, errors from SDK was created by Unknown User
I have a question concerning a certain function in the SDK. After I ran a simulation I go through all notices, warnings and error messages to verify validity of the result. I use the log-function for this purpose as proposed in the manual:
ssc_module.Log(idx, msg, type, time)
However, it seems like the function only returns warnings and errors. I ran SAM with a faulty meteo file on purpose. The run throws notices in the GUI version of SAM ("SAM calculated negative diffuse horizontal irradiance [...]"). However, no notices are returned when running the SAM sim core via the SDK and requesting the notices with the log-function. Warnings are thrown.
Any ideas if I am doing anything wrong? Is it possible to specify which kinds of messages are thrown?
Timo
Timo
06 Jun 2017 16:57 #5496
Replied by Paul Gilman on topic Notices, warnings, errors from SDK
Dear Timo,
That particular error message is generated by the pvsamv1 compute module. Is that the module you are running?
- Unknown User
07 Jun 2017 12:21 #5497
by Unknown User
Replied by Unknown User on topic Notices, warnings, errors from SDK
yes, that's the module I am running. Other messages which are unique to the module (e.g. "The product of number of modules along side and bottom for subarray...", "Inverter oversized: The maximum inverter output...", "Inverter undersized: The array output exceeded the inverter rating") are correctly returned by the log-function.
Any ideas?
Timo
Any ideas?
Timo
12 Jun 2017 12:34 #5498
Dear Timo,
The message "SAM calculated diffuse horizontal irradiance..." is only generated when specify that GHI and DNI are used as input (
irrad_radmode = 1
- Unknown User
13 Jun 2017 22:51 #5499
by Unknown User
thanks for the clarification, that was indeed the reason for the difference in behavior! In general I find this plausibility check very helpful, because a custom meteo file can easily be accidentally shifted by an hour or so. I have programmed by own routine that always performs this check now, but maybe for other users, always running this plausibility check could be helpful.
Timo
Timo
