Getting only 3 hours of generation per day even though there is 9 hours of GHI,DNI,DHI
- ecuaflo
23 Apr 2017 18:21 #5373
by ecuaflo
Getting only 3 hours of generation per day even though there is 9 hours of GHI,DNI,DHI was created by ecuaflo
I am attaching my script as well as on of my outputs so hopefully someone can see something I am missing. I don't understand what I'm doing wrong here since I expect there should be 9 hours of generation output a day instead of just 3 and running it on previous latitudes and longitudes has given me correct outputs. Please pardon the messy script and let me know if you need any clarification.
Florin
Florin
24 Apr 2017 10:03 #5374
Replied by Paul Gilman on topic Getting only 3 hours of generation per day even though there is 9 hours of GHI,DNI,DHI
Did you check the weather data for the latitude and longitude that generated those results?
You may want to test this by running a case in the desktop version of SAM using the same weather data to compare results to those of your script.
- ecuaflo
27 Apr 2017 18:10 #5375
by ecuaflo
Replied by ecuaflo on topic Getting only 3 hours of generation per day even though there is 9 hours of GHI,DNI,DHI
Thanks for the suggestion, Paul. It oddly seems to output the full 9 hours there. I can't get to the bottom of the discrepancy.
- Angus King
22 Jun 2017 02:29 #5376
by Angus King
Replied by Angus King on topic Getting only 3 hours of generation per day even though there is 9 hours of GHI,DNI,DHI
Florin
Still having issues?
I haven't looked at your code in detail so I may be guessing, but ... looking at the sample weather file that you've provided it seems the solar data is for GMT (or some other timezone) rather than -7 - the solar values peak at about 19:00 rather than 12:00. I believe the values should be for local time rather than GMT. If SAM is producing the correct results it must be adjusting for the timezone and hence moving the data/time "backward/forward" 7 hours. Try adjusting your data backwards 7 hours to see if you get the correct result.
Kind regards
Angus
Kind regards
Angus
