PVWatts V1 user_poa Assign Array
- MDuarte
28 Feb 2017 13:18 #5185
by MDuarte
PVWatts V1 user_poa Assign Array was created by MDuarte
Good evening Paul,
I have yet another question regarding the usage of POA values, this time in PVWatts v1. I´ve enabled usage of POA values by setting "enable_user_poa" to 1, but this returns an error, asking me to assign values to the array variable "user_poa"
To do this I´m trying to use the vbassc_data_set_array Function, but I´m running into trouble there.
I have my POA values in the last column of my weather file, but don´t know how to use the set_array function to retrieve that column as an array, could you help me out with this?
I´m guessing it should look something like this:
vbassc_data_set_array p_data, "user_array", value, length
But I don´t know what values to assign to value or length.
Thank you (once again!) for any and all help,
Kindest regards,
Miguel Duarte
Kindest regards,
Miguel Duarte
28 Feb 2017 15:01 #5186
Replied by Paul Gilman on topic PVWatts V1 user_poa Assign Array
Dear Miguel,
The
array should be a single column of data with 8760 rows.
You will have to write code in VBA to extract the data from the weather file and read it into a VBA array, and then use the vbassc_data_set_array() function to set the value of the SSC input.
The
user_poa
- MDuarte
01 Mar 2017 12:04 #5187
by MDuarte
Replied by MDuarte on topic PVWatts V1 user_poa Assign Array
Just to clear one last thing, for the data_set_array function, the "value" shall be the name of the array I create, and length shall be 8760, correct?
Thank you so much for your time,
Kindest,
Miguel D.
Kindest,
Miguel D.
02 Mar 2017 17:27 #5188
Dear Miguel,
Yes, that is correct.
