Exporting SAM Inputs to use in SDK
03 Jun 2016 16:36 #4495
Exporting SAM Inputs to use in SDK was created by Paul Gilman
Is there a way to export data from the SAM software (GUI) to run in the SDK tool?
In SAM 2016.3.14 and earlier, you can press the Shift-F5 keys to generate an LK script that assigns values to all of the SSC inputs for a case that you set up in SAM. You can modify and run that script in SDKtool, or convert it to one of the other languages supported by the SDK.
For the next version of SAM, we are developing a new feature that will export a functioning block of code in LK, C, C#, MATLAB, and Python to make it easier for you start writing your own code to use with SSC.
- Angus King
03 Jun 2016 20:48 #4496
by Angus King
Replied by Angus King on topic Exporting SAM Inputs to use in SDK
Paul
Cool!
Angus
Cool!
Angus
- Unknown User
10 Jul 2016 13:32 #4497
by Unknown User
Replied by Unknown User on topic Exporting SAM Inputs to use in SDK
Just wanted to say that I just had the same problem of getting started with using the SDK, and the Shift+F5 really helps! Great feature, much appreciated!
