tcsmolten_salt example failed in SDK
- Angus King
11 Jul 2015 10:03 #3131
by Angus King
Replied by Angus King on topic tcsmolten_salt example failed in SDK
Paul
Next question with tcsmolten_salt. I now encounter the following error:
tcsmolten_salt error [ 2 ]: unit 3 () type 'sam_mw_pt_type222' failed at initialization
I notice a post from 2012 (re receiver convective losses) that refers to the source for sam_mw_pt_Type222.f90 being available in the sam installation folder but can't find it in my current versions (maybe the packaging has changed).
Kind regards
AnGus
Kind regards
AnGus
- Angus King
15 Jul 2015 03:55 #3132
by Angus King
Paul
I've obtained the source from a Windows version so will look at the code to see if I can work it out.
Kind regards
AnGus
Kind regards
AnGus
15 Jul 2015 10:58 #3133
Replied by Paul Gilman on topic tcsmolten_salt example failed in SDK
Hi AnGus,
The TRNSYS source code files are available with SAM 2014.1.14 and older versions. Later versions no longer rely on the TRNSYS simulation engine, but do use essentially the same code (translated to C++) with a few modifications in some cases.
- Angus King
21 Jul 2015 06:44 #3134
by Angus King
Paul
I've progressed to where tcsmolten_salt is returning an array of (8760) 'nan' values for gen (hourly generation). I'll work through the variables I've set to see if I can solve the problem but any clues would help.
Kind regards
AnGus
Kind regards
AnGus
24 Jul 2015 14:46 #3135
Hi AnGus,
Would you mind [url=mailto:sam.support@nlr.gov?subject=tscmolten_salt%20output%20NaN t=_self]emailing me[/url] a copy of the script that generates those errors? My colleague promises he won't wait as long as last time to look at it.
- Angus King
27 Jul 2015 06:19 #3136
by Angus King
Paul
On it's way
Kind regards
AnGus
On it's way
Kind regards
AnGus
