Calculation of Perez model
- Mustafa
26 May 2022 06:09 - 26 May 2022 17:03 #11000
by Mustafa
Calculation of Perez model was created by Mustafa
I was looking into Perez model as implemented in SSC in cmod_pvwattsv0.cpp and comparing it to the technical handbook.
According to the module and other resources, the airmass should be
where b is the incidence angle.
Somehow in this line the equation for airmass is:
AIRMASS = 1.0 / (CZ + 0.15 * pow(93.9 - ZENITH, -1.253) );
and CZ in this line is:
CZ = cos(zen);
where zen is the sun's zenith in radiations and ZENITH the sun's zenith in degrees.
Shouldn't the equation for airmass replace CZ with cos(inc)? or am I missing something?
Thanks in advance.
Best,
Mustafa Alotbah
Attachment eq-am0.png not found
CZ = cos(zen);
Thanks in advance.
Best,
Mustafa Alotbah
Last edit: 26 May 2022 17:03 by Paul Gilman.
26 May 2022 17:18 #11001
Replied by Paul Gilman on topic Calculation of Perez model
Hi Mustafa,
Your observation is correct, but pvwattsv0 is a very outdated version of PVWatts.
The relevant code for the Perez model that is used by pvwattsv1 and later versions is here: github.com/NREL/ssc/blob/cd1b0110e43826d98fbe52bfac4f4f56f9d7afcc/shared/lib_irradproc.cpp#L2000
As of SAM 2021.12.02, SAM's implementation of PVWatts uses pvwattsv8.
- Mustafa
27 May 2022 03:29 #11003
by Mustafa
Replied by Mustafa on topic Calculation of Perez model
Thank you, I figured that out after I had published the post, but even in lib_irradproc.cpp, this line defines the airmass, which I think has the same issue, it uses CZ (Cos Zenith) instead of COSINC which is only defined afterwards.
Mustafa.
Mustafa.
- Mustafa
27 May 2022 05:24 - 27 May 2022 16:02 #11005
by Mustafa
another thing, in this line B is calculated as
B = D * F1 * ZC / ZH;
ZC being "a" in the handbook and ZH assumed to be "b", however, this does not seem to be correct, according to the handbook:
which is B in the code, and b is defined as
while, ZH is the maxiumum of 85 degrees and CZ again, instead of ZC/COSINC, check these lines out:
1967 CZ = cos(zen);
1968 ZH = (CZ > 0.0871557) ? CZ : 0.0871557; /* Maximum of 85 deg */
Mustafa
Attachment eq1.png not found
Attachment eq2.png not found
1967 CZ = cos(zen);
Mustafa
Last edit: 27 May 2022 16:02 by Paul Gilman.
27 May 2022 16:24 #11009
Hi Mustafa,
ZC is defined here based on cos(inc): github.com/NREL/ssc/blob/cd1b0110e43826d98fbe52bfac4f4f56f9d7afcc/shared/lib_irradproc.cpp#L2000
CZ is different, and is part of a modification to the Perez model that treats diffuse irradiance as isotropic when the zenith angle not between 0 and 87.5 degrees.
