Syntax error in PySAM stubs?
- Matan
08 Jul 2020 10:56 - 08 Jul 2020 16:49 #8407
by Matan
Syntax error in PySAM stubs? was created by Matan
I am trying to use mypy for static type checking my code, which implements PvwattsV7. mypy should be able to infer the typing on the Pvwatts api from the PVwatts7.pyi stub file. When I run mypy, I get this error.
Taking a look at the
Pvwattsv7.pyi
file, I came across what I think is a syntax error pretty quickly. Any function that has a type hint for an output is missing an end of line colon. ie.
Is this a syntax error?
Best,
Matan Guttmann
python3.7/site-packages/PySAM-stubs/Pvwattsv7.pyi:5: error: invalid syntax
Best,
Matan Guttmann
Last edit: 08 Jul 2020 16:49 by Paul Gilman.
- dguittet
10 Jul 2020 16:59 #8418
by dguittet
Replied by dguittet on topic Syntax error in PySAM stubs?
Hi Matan,
Yes it looks like a syntax error with the missing colon, thanks for reporting! I've fixed the issue as reported here: github.com/NREL/pysam/issues/47
I'll be releasing a new package version within a few weeks, so will not have fixed stub files available until then.
However, if you would like to have those fixes now, you can copy the updated files in the folder here into
Best,
Darice
Darice
- Matan
13 Jul 2020 10:49 #8423
by Matan
Replied by Matan on topic Syntax error in PySAM stubs?
Hello Darice,
Thank you so much for the quick reply! I will just wait for the next release, and do a
until then.
Best,
Matan
type-ignore
Best,
Matan
