3D shading tool
- Sophie Pelland
10 Mar 2020 14:54 #8029
by Sophie Pelland
3D shading tool was created by Sophie Pelland
I was wondering if the 3d shading tool from SAM is available open source and, if so, under what name? (More generally, is there a reference document listing all the models available in SSC?)
If not, are the equations used available elsewhere?
Sophie
Sophie
13 Mar 2020 11:45 #8039
Replied by Paul Gilman on topic 3D shading tool
Hi Sophie,
SAM's 3D Shade Calculator is part of the SAM project. The source code files are named s3[...].cpp like s3engine.cpp, s3objects, etc. in the src folder:
github.com/NREL/SAM/tree/develop/src
It is distributed as part of SAM, not as a standalone project.
The best way to explore all of the available models in SSC is to use SDKtool as described on the SDK page. With SDK you can see a list of all of the modules, show the inputs and outputs of each module, and write scripts to run the modules:
sam.nlr.gov/software-development-kit-sdk
You can also browse the list of files in the ssc folder of the SSC project -- compute module names are preceded by "cmod_". For example, the pvsamv1 module (Detailed Photovoltaic Model in the SAM user interface) code is in cmod_pvsamv1.cpp:
github.com/NREL/ssc/tree/develop/ssc
