mac os x - after 'generating report' the result leaves out information
- schmidly
16 Jan 2015 10:36 #2957
by schmidly
mac os x - after 'generating report' the result leaves out information was created by schmidly
dear paul/tech support team, when i generate a report on the mac os x updated version of SAM, there is missing data on the performance side of the reports. please see the attached screen shot (missing info boxed in red). is this a common/known issue or am i unique? please advise. thanks in advance, brian s.
16 Jan 2015 12:23 #2958
Replied by Paul Gilman on topic mac os x - after 'generating report' the result leaves out information
Hi Brian,
There are two issues here. The first has to do with unicode characters in the PDF -- for some reason the subscripted 2 is not being interpreted correctly in the OS X native PDF reader and appears as "??" Have you tried viewing the PDF in a different reader? We're investigating that. The characters are correctly displayed in Windows.
The second issue is that the Annual Results values are not being correctly calculated in the report generator template. I've fixed that for the update later this month.
- schmidly
16 Jan 2015 14:33 #2959
by schmidly
Replied by schmidly on topic mac os x - after 'generating report' the result leaves out information
Hello Paul, I tried opening the PDF in Adobe Acrobat Pro for Mac OS X and the "??" issue appears in that application as well. Thanks for fixing the Annual Results issue coming out in the update later this month. As always, these updates are greatly appreciated...Brian S.
