Negative Net Electric Output- Solarthermal and PVs Hybrid Plant
- elimorluq
13 Jan 2015 12:15 #2915
by elimorluq
Negative Net Electric Output- Solarthermal and PVs Hybrid Plant was created by elimorluq
I am trying to simulate the very new commercial solarthermal and photovoltaics hybrid solar plants. For the solarthermal part I am using a parabolic through model (PPA single owner). When I am configuring the solar thermal storage I set it in a way that the system only produce electricity by night and it stores thermal energy when there is daylight.
This results in a very little negative net electric output during the night period (when the system was suppossed to produce net energy) and positive results during day. That is, the system is doing exactly the opposite that it was suppossed to.
I guess SAM is programmed to generate electricity anytime there is sunlight. Is it possible to change this configuration?
THanks in advance.
EML
THanks in advance.
EML
13 Jan 2015 14:34 #2916
Replied by Paul Gilman on topic Negative Net Electric Output- Solarthermal and PVs Hybrid Plant
That's right. For CSP models with thermal energy storage, you cannot configure the dispatch control inputs on the Thermal Energy Storage page in such a way as to prevent the solar field from delivering heat to the power cycle. The dispatch control inputs determine the timing of energy from the storage system, but not from the solar field.
This description of the storage dispatch control inputs ( PDF 157 KB ) with examples might be helpful.
