irradproc error
- taranraj
26 Dec 2014 13:29 #2872
by taranraj
irradproc error was created by taranraj
I can't seem to run the irradproc module in the SDKtool. I've added all the data points 9in the data container) needed to run the module but I keep getting the error below:
Error: check fail: reason unassigned referenced, with 'irrad_mode!' for: beam time -1.000000
EXEC_FAIL: irradproc
I'm using the USA NY Albany (TMY2).csv available through SAM. I'm trying to calculate the POA Irradiance for a backtracking system using the Perez model and it won't work no matter what I've tried to do. Any help?
Taran
Taran
29 Dec 2014 10:18 #2873
Replied by Paul Gilman on topic irradproc error
Dear Taran,
Are you adding variables to the SDKtool data container by hand? It would be easier to troubleshoot if you use the script editor to write an LK script to set the values of the variables. Then you could send me the script for testing.
Also, the irradproc module has more than 6 "required" input variables.
Is there a reason not to use SAM to calculate the POA values? If you use SAM, you don't have to worry about setting values for all of those input variables. The solar performance models report POA values in the hourly results.
