Can't Register new version
- drmcmillian
02 Dec 2014 13:13 #2780
by drmcmillian
Can't Register new version was created by drmcmillian
While trying to register this copy of SAM, I get a message indicating cannot connect NREL to verify copy.
Not sure what's going here. My internet connection is working find.
02 Dec 2014 14:41 #2781
Replied by Paul Gilman on topic Can't Register new version
Dear Donald,
Do you know if you are using a web proxy server to connect to the internet? If so, that might be preventing SAM from connecting to the NREL servers. You can create a proxy configuration file to allow SAM to connect using your proxy server address.
To create a proxy configuration file:
If you do not have information about the proxy server or are not using one, please let me know and I will email you a registration key.
If SAM is open, close it.
Open the SAM installation folder (it contains the sam.exe executable file).
Use a text editor to create a new empty text file named proxy.txt
Put one line in the text file with your organization's web proxy server's address on a single line. For example if the server's address is "proxy-server.myorganization.org," then the file should have the single line:
To specify a custom port, add it to the name with a colon separator (no spaces). For example, if the server address is "proxy-server.myorganization.org," and the custom port number is 9142, the file should have the single line:
proxy-server.myorganization.org:9142
Save the file.
Close SAM.
- zjf1900
23 Dec 2014 00:13 #2782
by zjf1900
Replied by zjf1900 on topic Can't Register new version
Wish SAM can provide an option button for proxy setting in next version. I have found it in the help content, but maybe an option can make SAM much easier.
23 Dec 2014 10:31 #2783
We implemented this approach to test an eventual solution like you describe that would not require the file. Did the proxy configuration file solution work for you?
- zjf1900
06 Jan 2015 01:33 #2784
by zjf1900
Hello Paul
The proxy configuration file solution works for me.
I use SAM in my company where I must accesses internet with a proxy generally, but sometimes I need to work at field, so I need to delete/rename the configuration file because the proxy is not needed.
Best regards!
Best regards!
06 Jan 2015 09:08 #2785
Thank you for letting us know that the proxy configuration file works for you. It is helpful for us to know that you'd like a way to enable or disable it. We will consider that as an improvement to the current solution.
