Should azimuth use magnetic value, or true azimuth?
- lnbeauch
20 Oct 2014 09:29 #2638
by lnbeauch
Should azimuth use magnetic value, or true azimuth? was created by lnbeauch
I am modeling flat plate PV arrays. I have two azimuth values, magnetic and true. Does SAM have an automatic correction for azimuth, to correct for magnetic declination based on my project location? Or, should I input the corrected ("true") azimuth value directly to the model?
Thank you.
Thank you.
20 Oct 2014 11:23 #2639
Replied by Paul Gilman on topic Should azimuth use magnetic value, or true azimuth?
SAM's photovoltaic models expect the true azimuth value: An azimuth value of zero would be for an array facing true north (I mean "facing" with the assumption that the array is not horizontal).
