Central Receiver Plant Simulation Error
- Shanley
10 Oct 2014 01:58 #2607
by Shanley
Central Receiver Plant Simulation Error was created by Shanley
Good day
I'm having trouble with my simulation of a central receiver system. See attached. I imagine that it might be because the system is very small, however, I don't know how to remedy this.
Please assist.
Thanks.
Please assist.
Thanks.
10 Oct 2014 10:21 #2608
Replied by Paul Gilman on topic Central Receiver Plant Simulation Error
To run your model, I'll need a copy of the weather file you used. In any case, the small size of the system may be the cause of the problem (see here for more on that), or there may be something wrong with the weather file.
You may want to run some tests with a larger system. If the model runs, try gradually scaling down the size until it fails. If simulations fail using your weather file with the larger system, try using the PV model with the weather file to see if simulations fail there too. If they do, there's probably a problem with the weather file.
- Shanley
13 Oct 2014 06:19 #2609
by Shanley
Replied by Shanley on topic Central Receiver Plant Simulation Error
Thanks Paul
I will attached the weather file. However, I don't think that the weather is the problem. I have used the same weather file for linear Fresnel and parabolic trough systems without any issues. Also, with larger central receiver systems the simulation runs perfectly fine.
13 Oct 2014 10:04 #2610
The file you attached appears to be a summary of the data in the weather file, not the file itself.
I suspect the small size of the system is the problem.
