solar position
- Yuji Saito
02 Sep 2014 04:45 #2525
by Yuji Saito
solar position was created by Yuji Saito
I would like to confirm the calculation fomula of solar position used in SAM. I found the calculation fomula in the NREL document, "Technical Manual for the SAM Physical Trough Model", which was published in June, 2011. Is the fomula in the document used in the current version SAM?
Also, can we output the houly data of solar position in SAM?
Thank you for your advice.
02 Sep 2014 12:04 #2526
Replied by Paul Gilman on topic solar position
Yes, the physical trough reference manual describes the solar position equations in SAM's physical trough model. You can see the sun angle values in the hourly results. They are listed as "Solar azimuth angle," and "Solar elevation angle."
