Net plant power output (kWh), hourly AND Hourly Energy (kWh) for LFR
- williampaulbell
04 Jul 2014 20:28 #2403
by williampaulbell
Net plant power output (kWh), hourly AND Hourly Energy (kWh) for LFR was created by williampaulbell
Hello Paul
Could you explain the relationship between the following two hourly outputs from SAM for LFR technology please?
a. Net plant power output (kWh), hourly
b. Hourly Energy (kWh)
In my output, the "Net plant power output" is greater than the "Hourly Energy".
Regards
William Bell
Regards
William Bell
07 Jul 2014 09:51 #2404
Replied by Paul Gilman on topic Net plant power output (kWh), hourly AND Hourly Energy (kWh) for LFR
Dear William,
The Net Plant Power Output variable is the value calculated by the Linear Fresnel performance model. SAM applies additional performance adjustment factors based on the input values you specify on the Performance Adjustment page. For example, the default value of "Percent of annual output" is 96%, which would cause the Hourly Energy value to be 96% of the Net plant power output value.
The performance adjustment factors are intended to represent the impact of system outages and down time for maintenance, due to curtailment, or for other reasons.
