MICROINVERTERS BASED ARRAYS
- David H. Bachman
27 Feb 2014 05:33 #2180
by David H. Bachman
MICROINVERTERS BASED ARRAYS was created by David H. Bachman
How is the the array description entered that describes a micro inverter based array specifically 3X3 ground based array using Enphase 250 muicro inverters?
27 Feb 2014 11:47 #2181
Replied by Paul Gilman on topic MICROINVERTERS BASED ARRAYS
Dear David,
There is a description of how to model a system with Enphase inverters in SAM's help system, which you can find in SAM by clicking the Help menu. Here's a link to the online copy:
SAM Help - Microinverters
As mentioned in that description, SAM comes with a sample file with two examples of systems with microinverters. You can find the sample files by clicking Open sample file from SAM's File menu.
- Clean.Energy.Eng
28 Mar 2015 09:52 #2182
by Clean.Energy.Eng
Replied by Clean.Energy.Eng on topic MICROINVERTERS BASED ARRAYS
Paul, or whoever can help...
I am using the OSX version of SAM, and want to model a 30 panel/30 microinverter system. There seems to be a maximum of 4 sub-arrays... Also, I can't find the sample file, and there is no "Open sample file" in the SAM File menu...nor can i find the sample file in my downloads, or online.
30 Mar 2015 13:58 #2183
The sample file I mention above is for SAM 2014.1.14 and older versions of SAM. You can find a file that will work with SAM 2014.11.24 and later versions here:
/samples
Please see the notes in the sample file for tips on using the detailed photovoltaic model for a system with microinverters.
As for the number of subarrays -- why do you need more than four? The subarrays are intended for a rooftop array that is divided into different sections for a roof with multiple surfaces that face different directions. For a 30-panel array with 30 microinverters, you should set up one subarray (Subarray 1) and set the number of modules per string to 1, number of strings in parallel to 30, and number of inverters to 30.
/samples
- Clean.Energy.Eng
01 Apr 2015 12:26 #2184
by Clean.Energy.Eng
Aloha Paul,
I created the model the way you described, before contacting you, and initially got some weird results (losses over 25%). I went back and reviewed my inputs, might have changed something, output looks normal. My system will have 3 sub-arrays, on separate roof sections, with a different orientation for each sub-array...
I originally thought that with microinverters, one string per array might be required...hence the thought of needing more than four sub-arrays.
Now I am trying to put in shading data from a SunEye report, still trying to get the raw data...all I have now is the pdf report (very pretty, but can't input into SAM).
Thanks for the information and the links to the sample file.
Mahalo,
Steven L. "Red" Pike, Marine Engineer/Naval Architect
USCG Licensed Chief Engineer: Any Horsepower; Steam, Motor, or Gas Turbine
Mahalo,
