Saving Dispatch Schedules
- pkulbeik
30 Jan 2014 16:09 #2132
by pkulbeik
Saving Dispatch Schedules was created by pkulbeik
Recently, PG&E and SCE have changed their TOD factors. Is there a way to save these updated schedules as selections from the library? I currently use these tables in trough and tower models.
Pam
Pam
03 Feb 2014 15:01 #2133
Replied by Paul Gilman on topic Saving Dispatch Schedules
Hi Pam,
It is possible to use the Library Editor to add you own entries to any of SAM's libraries, including the TOD factor library. Hopefully the instructions in Help are enough to get you started. The TOD factors library is called "TOU Utility Rates."
Incidentally, we are planning an overhaul of SAM's library management system that will replace the current library format with simple comma-separated format that is easy to edit in a spreadsheet program. Stay tuned for that late this year.
