Always errors and shutsdown when running Kwajelin Atol
- hboulley
21 Jan 2014 09:58 #2123
by hboulley
Always errors and shutsdown when running Kwajelin Atol was created by hboulley
I've downloaded the Kwajelin EPW file and uploaded into the SAM and set all my parameters.
Every time I try to run the analysis, the SAM errors and closes.
I've updated to the latest version and still have this issue.
Any thoughts?
Any thoughts?
21 Jan 2014 10:50 #2124
Replied by Paul Gilman on topic Always errors and shutsdown when running Kwajelin Atol
That file has a problem with the header that causes SAM to close: The "state" column is empty. If you replace it with a hyphen, it should work.
I've attached a modified file to your original post that should fix the problem.
We will update the weather file reader in a future version of SAM to avoid this issue.
- hboulley
18 Jun 2014 00:06 #2125
by hboulley
Replied by hboulley on topic Always errors and shutsdown when running Kwajelin Atol
Thanks .. I missed this one! Appreciate it
