Steam Turbines Part-Load Isentropic Efficiency
- luiscoco
15 Jan 2014 06:20 #2082
by luiscoco
Steam Turbines Part-Load Isentropic Efficiency was created by luiscoco
Dear Sirs,
I reviewed in SAM, Type 234.for file, related to Balance of Plant power calculations, and I noticed Steam Turbine Isentropic Efficiency is a Fixed value: 88%.
I would like to know if you considered to introduce a correction factor to simulate steam turbines with part-load conditions. I think under part-load conditions steam turbines isentropic efficiency is not a Fixed value, as programmed, I suppose it could vary according to inlet steam flow, the so called 'flow factor'.
Best Regards,
Luis Coco
Best Regards,
Luis Coco
- mwagner
20 Jan 2014 09:57 #2083
by mwagner
Replied by mwagner on topic Steam Turbines Part-Load Isentropic Efficiency
Hello Luis,
You're correct that the isentropic efficiency varies as a function of turbine load. We've modeled the efficiency to have dependence on mass flow fraction (flow factor - as you mentioned). In Type 234, the turbine efficiency 'eta_t' is equal to the design point isentropic efficiency (0.88) times a flow-based correction factor as defined in the function 'eta_pl(...)'. The efficiency correction is:
eta_pl = 1.-(0.191-0.409*mf + 0.218*mf**2.)
where 'mf' is the flow rate relative to the design-point mass flow rate.
Best,
Mike Wagner
NREL
Best,
Mike Wagner
NREL
- luiscoco
22 Jan 2014 08:23 #2084
by luiscoco
Replied by luiscoco on topic Steam Turbines Part-Load Isentropic Efficiency
Thank you very much Michael for your response. I found in Type 234
the code the formula according Patnode thesis.
I would like to ask you if you know same Isentropic Efficiency formula
for Supercritical Carbon Dioxide Turbines and Compressors.
Best Regards,
Luis Coco
Best Regards,
Luis Coco
22 Jan 2014 12:35 #2085
Replied by Paul Gilman on topic Steam Turbines Part-Load Isentropic Efficiency
Dear Luis,
The off-design modeling work that we are most familiar with is from John Dyreby at UW-Madison. His paper from the 2011 Supercritical CO2 Power Cycle Symposium ("Modeling Off-Design Operation of a Supercritical Carbon Dioxide Brayton Cycle") describes his turbo-machinery modeling. His compressor model uses dimensionless flow and ideal head coefficients, and he presents of comparison of his model and data measured at Sandia National Laboratories. He also presents a standard gas turbine off-design relationship, but presently there are no public experimental data for comparison.
- luiscoco
23 Jan 2014 03:32 #2086
by luiscoco
Dear Paul and Michael, first of all thank you very again for your help.
