Calculation of EOT in physical trough model
- joey.hu
18 Dec 2013 22:13 #2046
by joey.hu
Calculation of EOT in physical trough model was created by joey.hu
Hello Paul,
When i tried to calculate the EOT(equation of time) according to your technical manual of physical trough model, i found some difference between your formula and the formula from other papers, your formula is:
EOT_sam = 9.2*(0.000075+0.001868*COS(
-0.032077*SIN(
-0.014615*COS(2*
-0.04089*SIN(2*
while the other is :
EOT_else = 229.18*(0.000075+0.001868*COS(
-0.032077*SIN(
-0.014615*COS(2*
-0.04089*SIN(2*
and the B is the same formula, i want to know why? and which one is the correct one?
Thanks and best regards
Joey
-0.032077*SIN(
-0.014615*COS(2*
-0.04089*SIN(2*
)while the other is :
-0.032077*SIN(
-0.014615*COS(2*
-0.04089*SIN(2*
)and the B is the same formula, i want to know why? and which one is the correct one?
Joey
19 Dec 2013 10:10 #2047
Replied by Paul Gilman on topic Calculation of EOT in physical trough model
Hi Joey,
You can see the actual equation in the physical trough model's source code, sam_mw_trough_Type250.f90, which you can find in your SAM installation folder (c:\SAM\2013.9.20\exelib\trnsys\source by default). The equation is on Line 809:
EOT = 229.2 * (0.000075 + 0.001868 * COS(
- 0.032077 * SIN(
- 0.014615 * COS(B*2.0) - 0.04089 * SIN(B*2.0))
That is different than Equation 2.27 in the reference manual. I suspect the error in the manual is a typo where the first two digits of 229.2 were omitted.
- 0.032077 * SIN(
- 0.014615 * COS(B*2.0) - 0.04089 * SIN(B*2.0))That is different than Equation 2.27 in the reference manual. I suspect the error in the manual is a typo where the first two digits of 229.2 were omitted.
- joey.hu
22 Dec 2013 17:29 #2048
by joey.hu
Replied by joey.hu on topic Calculation of EOT in physical trough model
Ok, i see, thank you.
Best regards
Joey
Best regards
Joey
- Jack Li
28 Aug 2015 02:29 #2049
by Jack Li
Replied by Jack Li on topic Calculation of EOT in physical trough model
I can not found the physical trough model's source code, for example sam_mw_trough_Type250.f90, in SAM 2015.6.30. Are these codes containing in this version? If it is not contained, how can i found them? Thanks.
Jack.
Jack.
28 Aug 2015 09:12 #2050
- Jack Li
28 Aug 2015 18:54 #2051
by Jack Li
Thanks for the answer and help.
Jack.
Jack.
