SWRF vs. SRW file extension
- ibm214
06 Dec 2013 12:42 #2016
by ibm214
SWRF vs. SRW file extension was created by ibm214
I am trying to use the SDK to generate a simplified version on SAM for wind. My team is currently having trouble with the wind module within the development core. I assume thatthe problem that we are encountering is due to a different file type being input into the program. The module requests an SWRF file while the weather file downloaded from SAM is an SRW file. Is there an easy fix to this problem?
Thanks!
Thanks!
06 Dec 2013 14:29 #2017
Replied by Paul Gilman on topic SWRF vs. SRW file extension
The SSC's windpower module reads wind resource data from a file in the SRW format. The file_name label ("local SWRF file path") is incorrect.
You should assign a string with the SRW file's complete path and file name to the file_name variable. For example:
file_name = "C:/SAM/2013.9.20/weather/AR Northwestern-Flat Lands.srw"
- ibm214
08 Dec 2013 16:00 #2018
by ibm214
Replied by ibm214 on topic SWRF vs. SRW file extension
Thanks that clears up one of the issues, but I still haven't been able to get the wind module to work properly. Is there an example for a wind location that is available. I have found the solar examples provided with the ssc to be very helpful.
Ian
Ian
09 Dec 2013 09:59 #2019
Hi Ian,
Unfortunately, we do not have sample code for SDK's wind module. If you are willing, perhaps we could use your work as an example, after we get it working.
What specific problems are you having with the module? If you don't mind sending me a copy of your code, I'll try to help you troubleshoot. You can either attach it to your original post above, or email it as an attachment to SAM support .
- ibm214
10 Dec 2013 13:32 #2020
by ibm214
Ian
Ian
